I have a question for you concerning GPIOs on the JP7
port of the SnapAmp.
Typically, we would use optos for our encoder indexes,
however in our latest build we have utilized all 8 of the
optos. We are looking to use a couple of GPIOs on the
SnapAmp for the motor index, the encoder index is a 5V
signal, and I under the impression that the GPIOs from pin
1 to 14 are 5V tolerant.
While tuning the motors, the bit's state would
occasionally flicker, causing us issues. If the problem is
a floating logic state, I believe a pull-down resistor
would solve it... However I wanted to ask you if there was
a specific resistor value that you would recommend, or if
you have an alternative solution?
Thanks.
With best regards,
Ben Stevenson
